首页 > 国外线缆 > UL1581-2011Flammality of Plastic Materials for Par
[标准更新信息 ] UL1581-2011Flammality of Plastic Materials for Par
P: 2012-11-19 09:29:06
UL1581-2011Flammality of Plastic Materials for Parts in Devices and Appliances
更详细信息及下载:更详细信息及下载:http://www.cestr.com/cn/news/show.asp?id=85
http://www.cestr.com/cn/support/down.asp
Summary of Topics摘要信息:
This revision to ANSI/UL 1581 includes the following change in requirements此次ANSI/UL 1581修订包含以下修改信息:
Reinstatement of Several Physical Properties Tables恢复一些物理属性表
Deletion of Construction Requirements for CPE Insulation for Type RHW from Table 50.34
删除表50.34 RHW型电线CPE绝缘构造表
Addition of Test Speeds and Deletion of Density Requirements for PE Materials in Tables 50.134 and 50.136
在表50.134 50.136中增加PE材料的测试速度和删除密度要求
Revision of Description of Cotton Used in Flame Tests修订描述用于燃烧测试的棉花要求
Addition of Physical Properties Requirements for PVC/Polyurethane Blend
增加PVC(聚氯乙烯)/ Polyurethane(聚氨酯)混合物物性要求
UL2556-2011 Wire and Cable Test Methods—2011年已出修订版,新版即将公布, 下载:http://www.cestr.com/cn/support/down.asp
法国插头插座标准更新NF C 61-314 2008/A1 2010Plugs and socket-outlets for household and similar purposes---6 A/250 V and 16 A/250 V systemsNF C 61-3142010生效时间2013.1.1),老版标准NFC 61 3142003 NFC 61 3142008 都是201311日到期
NF C 61-314 2008/A1 2010标准下载:http://www.cestr.com/cn/support/down.asp
BS1363-2012标准变更内容详细细节Specific implications for fused plugs (BS 1363: 1995) http://www.cestr.com/cn/news/show.asp?id=59
BS1363-2012标准更新和下载,在2015.05.31生效,新标准培训讲义我们第一时间共享,请关注(BS1363-1: 1995+A42012 BS1363-2: 1995+A42012BS1363-4: 1995+A42012)http://www.cestr.com/cn/news/show.asp?id=58
JB/T8734.1-2012JB/T8734.2-2012JB/T8734.3-2012JB/T8734.4-2012JB/T8734.5-2012JB/T8734.6-2012 电线标准发布,实施日期2012-11-01 http://www.cestr.com/cn/news/show.asp?id=57
UL94电子产品塑料阻燃性规范修改, UL94-2012生效时间2013-10.23(October 23, 2012)http://www.cestr.com/cn/news/show.asp?id=47   http://www.cestr.com/cn/news/show.asp?id=55
EN50525-2011(BS EN50525-2011)新标准下载,EN50525新标准在20141月生效: http://www.cestr.com/cn/news/show.asp?id=46
AS/NZS 3112:2011/Amdt 1:2012AS/NZS 3112:2012)认可和测试规范-插头和插座-澳洲插头插座标准http://www.cestr.com/cn/news/show.asp?id=49
沙特阿拉伯插头插座标准SASO2203SASO2204SASO443: http://www.cestr.com/cn/news/show.asp?id=51
插头电源线综合测试机电气性能标准符合性、测试原理、要求和分析http://www.cestr.com/cn/news/show.asp?id=54
UL2556-2011电线燃烧印字要求(FT1, FT2, FT4, FT6VW-1燃烧等级区别,UL/CSA电线燃烧标志识别,美规电线耐燃等级比较。)http://www.cestr.com/cn/news/show.asp?id=53
各国插头电源线摇摆测试标准汇编-修订版http://www.cestr.com/cn/news/show.asp?id=52
西思特代理世界各国电线电缆及插头电源线,延长线,连接器产品认证、委托测试及技术咨询等服务:
中国CCC、德国VDE、荷兰DEKRA(KEMA)、韩国KC、意大利IMQ、瑞士SEV、芬兰FIMKO、瑞典SEMKO、丹麦DEMKO、 挪威NEMKO、奥地利OVE、英国BSI、英国ASTA、美国ULCUL)、加拿大CSA、日本PSE、印度BIS 、南非SABS、巴西UCIEESAA澳洲,阿根廷IRAM,以色列SII ......
联络人:张生/Mr.Luke
电话: +86-755-27290351
传真: +86-755-27294806
手机: 13612834185
QQ: 493278805
Email: okgang@cestr.com; luke@cestr.com.cn
wire superimposing - 架空明线增设 点赞(0) 投诉
P: 2012-11-19 10:17:04
不想细看
die polishing equipment - 线模抛光设备 点赞(0) 投诉
